Summit racing/late model restoration list
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
So i put my list together finally (ended up with a smaller budget due to me giving money to help out my family) anyways, let me know if this seems right in terms of brands and price
UPR Sub-frame connectors/torque box reinforcement
Eibach pro-kit lowering springs
Clutch Kit includes:
1 x RAM-88794HD HDX Clutch Kit
1 x Ford Racing 10.5" Flywheel
1 x Ford Racing Pressure Plate Bolt & Dowell Pin Kit
6 x Ford Racing Flywheel Bolts
1 x 50resto T5 Steel Input Bearing Retainer
1 x Ford Racing Rear main seal
1 x Ford Racing Pilot bearing
Flowmaster Delta Force Single chambers
MSD 6al ignition box
FRPP 4.10 gears
BBK fenderwell Cold Air intake
FRPP 24# Injectors
Auto-meter RMP pill Shift light
A/c Gauge Cage
C&L 24# calibrated MAF
Walbro 255lph Fuel pump
Holley Adjustable Fuel Pressure Regulator
getting a 10% discount from summit, and trying to swing a deal with LMR :D
i know its nothing wild but im trying to build a solid foundation for this car
FRPP 4.10 gears
FRPP 24# Injectors
A/c Gauge Cage
Well, Eibach is doing their 10% rebate again this year.
http://eibach.com/cgi-bin/start.exe/eibach/index.html?entry=y&thid=135
On the Injectors, if you're running a wet kit the injector upgrade is not needed. If you are leaning out it is due to too small of a fuel jet, too small of a fuel pump, or low fuel pressure. What kit are you running & how big of a shot?
+1, the whole idea behind a "wet" kit is that the nitrous system's nozzle supplies its own fuel. The engine's injectors do nothing to supply extra fuel for the nitrous nor does the engine have any way of knowing you're spraying N2O other than the O2 sensors showing a lean condition, in which case the EECIV wouldn't respond quickly enough anyway.
i know the wet kit supplies its own fuel. but i figured since ill be running a different cam and a larger intake (heads a bit down the road) and may switch over to a dry kit( friend with an NOS kit i can run a larger shot with) i may as well go ahead and install the injectors... maybe i was incorrect
Oh, OK. With those modifications planned, going to bigger injectors would probably be a good idea. I thought your only motivation was because of the wet kit you have now.
Yeah sorry if I was unclear...I'm not as stupid as I seem :D...close though
I was very pleased with lrs today, had an issue and they let me swap out parts and do some financial adjusting
