sun roof needs help
  • Thread starter Thread starter CHRISSOLES
  • Start date Start date Feb 3, 2011
CHRISSOLES
20
CALIFORNIA
Feb 3, 2011
  • Feb 3, 2011
i just got my 89 gt foxbody but it came with a leaking sunroof i replaced the thick rubber but not the cracked rubber in the picture. i dont no how i would fix it or were to get good supplies please help.
4G-KDMP
935
CA
Feb 3, 2011
  • Feb 3, 2011
It sounds like you might need this
1979-93 Mustang Sunroof Glass Weatherstrip by 50resto at LRS - Same Day Shipping!
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Feb 3, 2011
  • Feb 3, 2011
Take some compressed air and blow out the four sunroof drains. If they are blocked, you might need to snake or replace them.
C
CHM92stangman
9
  • Feb 3, 2011
My 1992 has a sunroof as well and just before I got it from my friend he had replaced both the sunroof to body seal and the glass rubber seal that you showed that needs replaced but it still leaked. I cleaned each drain hole and made sure the tubes were not leaking and found that it was coming from between the plastic guides that the front hinge's of the sunroof fit into and the body(one on each side front side of sunroof opening). Check these as well as you check the drain tubes.
CHRISSOLES
20
CALIFORNIA
Feb 3, 2011
  • Feb 3, 2011
thanx
im going to check all these tomorrow ... thanks for the help
CHRISSOLES
20
CALIFORNIA
Feb 4, 2011
  • Feb 4, 2011
were are th e sunroof drains located ...
first mustang still learning.......
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Feb 4, 2011
  • Feb 4, 2011
Take the sunroof out and look inside the "moat". There are two holes in the front corners and two in the rear corners. The front tubes drain in front of the door and the rear tubes drain behind the door.
Also, you'll see the guides at front. Make sure they dont leak as well. Pouring some water in the "moat" might help track down leaks
Bryan83taco
554
40
39
SF Bay
Feb 4, 2011
  • Feb 4, 2011
All great advice. LRS also sells a 2 piece sunroof kit that includes the lower weather stripping. I just recently replaced my seals.
1979-93 Mustang 2 Piece Sunroof Weatherstrip Kit by 50resto at LRS - Same Day Shipping!
sd331
69
NJ
Feb 4, 2011
  • Feb 4, 2011
i put some clear silicone around the front plastic guides for help against leaks
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
