Super clean 88 mustang LX 5.0
glide1
IL
Super Clean car, the underneath is flawless gloss black painted. You would be hard pressed to find a nicer car. Located in IL, Checkout all my albums to see all the pics. I have $24,000.00 invested looking to get $8,000.00 for it. Any questions you can email me at [email protected] or call me at
1-708-707-0142. Most work done by Dean's Performance in St. Charles, IL
Is Ran by Anderson Ford PMS system
Here are a list of mods
CHP street fighter 347
Edelbrock performer heads
FMS e-cam, timing chain, roller rockers, 24Lb injectors, valve covers, water pump
Holley systemax upper and lower intake,
Pro-m 75mm mass air
BBK 70mm t-body,
Aeromotive fuel reg,
Accel fule pressure guage,
Walbro 255lph fuel pump,
Summit alum radiator and catch can, Summit (mallory) Digital ignition and coil,
Derale dual e-fans,
March bracket and pulley kit
Full mac exhaust (Lt's, prochamber, 2 1/2" dumps)
Anderson PMS
Autometer oil press and water temp guages
Suspension & drivetrain:
UPR tubular k-member kit (coil-overs, a-arms, and billet c/c plates),
Manual rack kit with steering shaft
Lakewood 70/30's front, and 50/50's rear,
Maximum motorsports subframe conectors,
FMS aluminum driveshaft
HPM D/S safety loop
Steeda adjustable upper control arms , and aluminum lowers,
FMS 3.55 gear
Axle tubes welded and painted and upper torque boxes re-welded,
Moser 31spline c-clip axles
Eaton detroit tru-trac diff
T/A performance girdle
Maximum motorsports clutch cable kit
Centerforce clutch
Heavy Duty built Tremec 5-spd
Steeda shifter
Energy suspension motor mounts and trans mount
New powerslot front rotors
New pads and new calipers
New drums and rear shoes
Pony rims with goodyear ds3's front and new BFG 255/50 drag radials rear
Misc:
Cervini 3" cowl hood with FMS hood pins
Back 3 windows tinted by Riggs Brothers
