SUPERCHARGED 331 DSS STROKER 89 MUSTANG GT CONVERTIBLE (over 40 pics inside)
My friend is moving and unfortunately can not take his Mustang with him.
1989 MUSTANG GT factory 5.0 5spd car with ONLY 34k ORIGINAL MILES & ONLY 6,000 Miles on DRIVETRAIN!
Clean Car Fax Report!
There have only been 3 owners since new and there is over $30,000 in extras invested into this car. The new owner will get extensive records & receipts from DSS, Vortech, TFS, Anderson & McCarville Ford, Summit Racing, S-K Speed and much more!
Clean NY Title In Hand Ready To Transfer To New Owner.
BODY:
Custom 2.5” Bolt On Cowl Induction Hood
Cervini's Complete Body Kit including STALKER front bumper cover with COBRA side skirts & rear bumper
Original SALEEN rear wing
Custom 17” ROH ZR Wheels (orig receipt for over $1,800) w/Great Tires including rear Mickey Thompson Drag Radials
Very Clean Black Exterior Paint
Tight Body Lines On Every Panel (see pics)
Door Hinges DO NOT Hang
NO Surface Rust Under Doors or trunk (see pics)
Pin Straight & Rust Free Frame Rails (see pics)
Perfect Fender Aprons (no crinkles or cracks from accidents)
Absolutely Solid Floor Boards
Original Top in nice shape (operates up/down)
INTERIOR:
Very Clean Factory Grey Leather Interior (no rips/tears)
Custom Rear Seat Delete Kit
Complete Factory Power Options (top, windows, locks, mirrors, etc)
Full Aftermarket Gauges & Air Fuel Ratio Meter Neatly Mounted
PMS EFI Computer System Neatly Mounted above glove box
6 point Roll Cage w/full padding
SIMPSON Driver Side Race Harness Seat Belt
Aftermarket Stereo System
DRIVETRAIN / PERFORMANCE:
VORTECH V1 14lb Supercharger
VORTECH Mondo Blow Off Valve
ANDERSON 4" Power Pipe
92mm Mass Air Flow Sensor
75mm Throttle Body & EGR Spacer
60 # Injectors
WELDON 2025A Fuel Pump & Fuel Pressure Regulator
AEROMOTIVE Fuel Pump Controller (trunk mount)
Sumped Fuel Tank
TRICK FLOW "R" Series Upper & Lower Intake Manifold w/1" spacer
TRICK FLOW Twisted Wedge Heads (202 valves) & Valve Covers
DSS UPGRADED IRON EAGLE 4 BOLT MAIN 331 STROKER X BLOCK Custom built for Supercharged application (complete long block build sheet available which totals $9,646)
FORD B451 Blower Designed Camshaft
Canton 7qt Oil Pan
MDS 6AL Ignition w/Adjustable Rev Limiter
MSD Blaster Coil
Griffin 4 Core Aluminum Radiator
Anderson Ford PMS Programmable Engine Management Computer System
ALL THE BEST PARTS IN THE SHORT BLOCK...NO EXPENSE SPARED!
1 3/4" MAC Long Tube Headers
MAC 2 1/2" Pro-Chamber H-Pipe
2.5" Flowmaster Catback with 3" Stainless tips
Aluminum Flywheel
SPEC Stage 3 Clutch Kit
SFI Scattershied / Bellhousing
WORLD CLASS T-5 5 speed w/all upgraded internals
HURST Short Throw Shifter
Aluminum Driveshaft
Driveshaft Loop
8.8 Rear w/Auburn Pro-Series Posi Unit
4:10 Ring & Pinion Set
MOSER 31 Spline Axles
MOSER C-Clip Eliminators
SVO Rear End Cover
Adjustable Caster Camber Plates
Hotchkis Adjustable Upper & Lower Control Arms
EIBACH Drag Launch Kit w/Air Bag In Rear Spring
KONI Adjustable Suspension
New BEAR Cross Drilled & Slotted Rotors
New HAWK Front Brake Pads
New Front Calipers, Rear Drums, Rear Brake Shoes, Rear Wheel Cylinders
Front & Rear Steel Brake Lines
New Master Cylinder
6 Point Roll Cage
Driveshaft Loop
Sub-Frame Connectors
FLAMING RIVER Steering Shaft
LINE LOCK on shifter T-Handle
Autometer 5" Monster Tach w/Shift Light
Aftermarket Fuel Pressure Guage
Aftermarket Boost Guage
Air / Fuel Ratio Meter
The asking price is ONLY ASKING $14,000 for this car & you WILL NOT find another one like it!
ONLY SERIOUS INQUIRIES CALL 631-523-1340 (located in NY Zip Code 11741)
CLICK HERE TO VIEW AN ENTIRE PHOTO ALBUM OF 40+ PICTURES:
Jareds Convertible :: Jareds Convertible slideshow by inshurit - Photobucket
Thank You For Looking!
MH-47gMECHANIC...Give me a couple days, if I can convince my frind to pull out his drive train and all other extras, maybe he will sell you the stripped roller for $4,500.
Serious Inquiries ONLY Please!
This is NOT your average abused Fox Body!
I spoke with the owner of the car to verify that there was 1 dyno tune pass and the car made 585 HP to rear wheels. During this single dyno tune the car had to be shut down at 5,000 RPM due to inadequate fuel system.
After this the sump tank & full aftermarket fuel system was installed. Car was re tuned on the dyno 1 more time.
The car obviously has much more than 585 rear wheel HP, but that is the only documentation at this time.
Please call owner at 631-523-1340 with additional questions!
I talked to him today to set up arraignments and am purchasing the car for the asking price of $10,500.
Been out of the Mustang world for a while and thought this is a hell of a way back in.
Sold my Harley yesterday to buy this car.
I will take it up to Alternative in spring and have it dyno tuned.
Thanks.
It is pretty nice. I am immediately switching out carpet to black, reinstalling a back seat, installing Mach 1 upholstery to all seats, new top, black headlights, and go from there. For the price though.......I am quite happy.
