If I could add just a bit more here I would say I agree with Kyle
about wanting to be cautious about too much spark
He advised to dial it back a bit and I would say a couple would not hurt
and
Maybe even to start out ...... less ....... a good bit less
I looked at the stock GT spark table and here is what I saw.
At around 85% to 100% max load or wot, you will be seeing 21 to 26 degrees from the pcm in a rpm range from 2K to 5K
At around 50% or mid load ... it even goes higher
1500/32 ... 2000/34 ... 2500/37 ... 3k/35 ... 4k/35 ... 5k/35
If you set your dizzy at 8 ... then you would do the -2 thing to all those above values btw
Keep in mind these values could + or - a bit depending on ............
various things but still ............
You can now see why Kyle threw up the ... red flag of caution
With a fmu ... the ratio is anybodys guess at times
I would dial back more spark!
One more thing you might wanna consider ..............
Dialing back more spark!
If you are at a mid load driving condition and then nail it .............
It don't instantly go to the lower max load spark values
At first ... SCREW THE POWER
Get stuff all set so you don't have to become .............
A SBF HG Changing Expert
Forced Combos can pop em quick
... REAL QUICK
Just a little heads up info
and
I look forward to seeing what you come up with
so
Let us know all about it
Grady
