SuperCharger and Vaccum
tjh566
608
Northern Va
Im Thinking about a custom Supercharger mounted ontop of my engine in place of the upper intake, Now I remember with my intake swap there was vaccum lines connected to the upper intake... what do I do with those to get vaccum?? thanks for the time!
kenne bell superchargers are mounted like that
you'll need to drill and tap fittings for them, after the throttle body, but before the boost side of the supercharger
the fuel pressure regulator should see the boost though
tjh566 said:
wouldnt that blow the hose off the regulator tho?
The pressure regulator hose is at ~15 psi just sitting there (standard atmospheric pressure), so boost means 15psi + whatever boost you get, whereas vacuum is 15psi - whatever vacuum you are drawing.
Scott
