Well I just got my powerdyne on and I drove adround for alittle while and it blew the pcv valve out. Any ideas?!?
shttygtstang said:when going to a sc set up your suppose to use valve cover vent/arfilter set up
shttygtstang said:when going to a sc set up your suppose to use valve cover vent/arfilter set up .
your lucky you didnt blow your rear main seal.
I only know this because i couldnt figure out y i kept blowing valve cover after valve cover gasket. but if you think abought it all the positive presure your pcv is suppose to vent into your intake is doing one big circle and it has no were to go .hope i shed some light on this .
Also do a search on my name i had this problem others like hissin50 and mr micheal yount helped me a great deal.
9T3SVT said:There are mixed reviews on that actually. Even though a lot of people use them to reduce the pressure you really don't want to introduce the un-metered air that comes from those breathers.
Did you change the PCV when you did the install? Did you disconnect the vacuum line that goes from the T/B to the oil filler?
RacEoHolic330 said:You MUST disconnect the line going from the oil filler tube to the TB and plug the nipple on the throttle body. If you don't do this you are allowing boost to enter the crankcase.
tunedin302 said:DO THIS IMMEDIATELY!!
9T3SVT said:For one, the breather is not the answer and I wouldn't even reccomend it myself. For two, removing that line is exactly what he needs to do. It is a clear step for any S/C install and leaving it hooked up will cause bigger problems.
So yes it is a big deal and he could have a clogged PCV anyway. That too is yet another skipped step during his S/C install. All the blowers I have installed say you need to replace it.
All we are doing is offering him the right advice, you seem to just be telling him what fixed your car.
bentley429 said:Ill let you all know what happens this weekend with it, maybe some imports will be........![]()
9T3SVT said:Before you push your car hard you NEED to get it tuned or at least see what the air fuel ratio is at.
bentley429 said:How much did it cost you to get yours tuned?
