  • SN95 4.6L Mustang Tech
Supercharger Dyno Graph Comparison
  • Thread starter Thread starter StangJonGT
  • Start date Start date Feb 19, 2004
First Prev 2 of 2
00s281sc368
532
Fremont, CA
Feb 20, 2004
#21
  • Feb 20, 2004
  • #21
Yes, power is still climbing, and rev limiter is removed but we stopped at 6K rpm anyway. I don't think it's safe beyond with the stock heads, valves & springs... Also A/F was going back up, maybe boost-a-pump limits ?
yellow2kgt
175
Fishersville,va
Feb 20, 2004
#22
  • Feb 20, 2004
  • #22
I figured it out. Here is my graph
StangJonGT
1,329
Seattle
Feb 20, 2004
#23
  • Feb 20, 2004
  • #23
Decent numbers yellow, although I would think you have room for improvement with your 10lbs.
00s281--are you still running the stock fuel pump? I would think it would be time to upgrade your fuel system--although I don't know what Saleen puts in there.
Jon
00s281sc368
532
Fremont, CA
Feb 20, 2004
#24
  • Feb 20, 2004
  • #24
Saleen does not change the fuel pump! I only have the KB boost-a-pump that comes with the kit
ASilver2001GT
636
Huntsville/Birmingham, AL
Feb 20, 2004
#25
  • Feb 20, 2004
  • #25
00s281sc368 said:
Here is mine. KenneBell @9psi on stock block and saleen borla cat-back.
Why are you so rich? Hell when you stopped the dyno at 6000, you had a 12:1 A/F ratio, that right there is safe. I'm running about 11.5:1 all the way across
00s281sc368
532
Fremont, CA
Feb 20, 2004
#26
  • Feb 20, 2004
  • #26
According to KB, the measurement is off by 1, should be 11.5 all the way. So if everything is shifted by 1 it is safe to stop at 6000rpm... I don't spend much time above 6K anyway, so I don't think it's worth the risk...
StangJonGT
1,329
Seattle
Feb 21, 2004
#27
  • Feb 21, 2004
  • #27
I'll bet it would spin right past 6K if you let it. How does that thing drive?
Jon
ASilver2001GT
636
Feb 21, 2004
#28
  • Feb 21, 2004
  • #28
You've got some power left in that car, all you need to do is lean it out.
First Prev 2 of 2
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Y
Dyno Comparison for TFS 44cc Ported Heads vs PI Ported Heads with same VT Stage 2 Cams
  • Yel2002GTAuto
  • Oct 13, 2022
10K
SN95 4.6L Mustang Tech Jan 29, 2023
Yel2002GTAuto
Y
Engine Cam idle and timing questions - big cam, little knowledge
  • Justin87
  • Jul 6, 2021
11K
Fox 5.0 Mustang Tech Jul 31, 2021
Middleagecrisis
M
Engine 347 Supercharge Planning
  • HeatShield
  • Oct 17, 2020
3K
Fox 5.0 Mustang Tech Apr 27, 2021
Haste347
H
300WHP for $3000
  • Levi.Productions
  • Feb 9, 2020
4K
1996 - 2004 SN95 Mustang -General/Talk- Feb 10, 2020
Sluggie24
