supercharger fmu question help
  • Thread starter Thread starter mat82284
  • Start date Start date May 5, 2004
M
mat82284
889
  • May 5, 2004
i have the whole kit but the fmu i bought it from someone and he didnt send the fmu its on the way now but can i install this without it or will it mess up my car???
88stangmangt
2,332
Stafford,VA
May 5, 2004
  • May 5, 2004
ya you have to have it unless you run a FPR i believe?
M
mat82284
889
  • May 5, 2004
whats fpr???
88stangmangt
2,332
Stafford,VA
May 5, 2004
  • May 5, 2004
Fuel Pressure Regulator.
M
mat82284
889
  • May 5, 2004
i have a stock fuel pressure regulator but thats all i know. i have a 92 mustang 19lb injectors
88stangmangt
2,332
Stafford,VA
May 5, 2004
  • May 5, 2004
ya but that is non-adjustable and isnt worth $hit. you will be fine with the FMU.
RydeOn
Licensed to Chill
6,273
orange county, CA
May 5, 2004
  • May 5, 2004
Dont run it without the FMU, wait till it comes.
M
mat82284
889
  • May 5, 2004
i guess ill wait but if i installed it can i use the stock belt to run it with out running the supercharger i seen this pic
88stangmangt
2,332
Stafford,VA
May 5, 2004
  • May 5, 2004
ya that would work some people do that for winter or when it is hott.
M
mat82284
889
#10
  • May 6, 2004
  • #10
if i just got fuel injectors how do i know what size to get instead of useing fmu i would rather upgrade anyways should i get 30lb or more??? im going to run it at 6psi for now but may up to 9 later later on.
RydeOn
Licensed to Chill
6,273
orange county, CA
May 6, 2004
#11
  • May 6, 2004
  • #11
If you are using stock long block than the 30# injectors will be good up to 9 psi.
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Fuel Bad regulator diaphragm?
  • JD1964
  • May 20, 2025
2K
Fox 5.0 Mustang Tech Jul 16, 2025
JD1964
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
