Supercharger Help?
85fox
28
Texas
Heres the deal. I own a 1985 Mustang Hatch with 105,000 miles on it. It is completely stock under the hood from oil pan to air cleaner. I have 2 1/2in catback exhaust, 3:73 gears, and Lakewood dragshocks in the rear. I want to get a weiand 174 powercharger for it. I have some questions first. Will the bottom end hold up and if so for how long with some abuse here and there. Will the T-5 tranny hold up as well as the 8.8 rearend. And how much power could I expect. Super Rod magazine said a bone stock 302 w/ stock heads and everything made 474 flywheel power but Im skeptical?? Anybody that has this blower or has any imput at all it wil be greatly appreciated!!!!!:shrug:
carbed87 said:
i havent owned it, but im damn sure youre not gonna make 400hp. try somewhere around 300-350
the ony thing id be skepticl about is the bottom end hoding up.
:Word: Were those things forged back then. I have a 92, all stock w/ a p1sc 14 lbs and 150 k on it running fine but only pushing 350.
How well you treat it once the additional power is there will determine how long the tranny and rear end last. Roots blowers make power very quickly. If you've got good traction and an unforgiving clutch, you'll be able to twist that drivetrain into a pretzel in no time. Determine the health of your motor before adding the blower. Compression and leak down test would be good for starters. Plan on getting the whole combo tuned CORRECTLY. If you just slap it on and hit the gas, I'll give it less than a 100 miles before it's all toast.
Would it be worth my time to drop in my other 30,000 mile stock 85 motor?
By tuning would messing w/ the carb and retarding the timing be sufficent amount of tuning??
And would I be better off putting in a high performance clutch like a centerforce or just a stock replacment???
I would get either a Centerforce dual friction or a spec 2/3. The stock clutch won't hold that power, but then again the tranny won't hold out too long either.
first build your foundation then down the road get a power adder. I dont see the point of putting a supercharger on an engine with that many miles. Use the money for your supercharger to build the bottom end h/c/i, tranny, and rear. Then down the road get a supercharger and your car will be able to handle all the extra power. Doesn't make sense to go backwards...
:stupid:
thank you $uperstang, atleast one person agrees with me so far...
I'll agree with you. I also firmly believe in having a plan before adding "go-fast" parts to any car. Things need to be thought through at least 2 times before spending money.
Things to consider about going faster:
1) Stoping becomes harder
2) Turning becomes more challenging
3) Safety systems incase you crash should all be functioning
I believe it's JRicker that has the "before you build a house you pour a good foundation" in his signature. It's some good advice.
I'm not saying don't buy a charger or turbo... by all means - my car will have one when I am done with it. You just have to plan your moves.
