Supercharger ques.
mustang94mod
28
Concord
I am thinking about buying a powerdyne supercharger that was upgraded to a bd-11a for a 94-95 mustang. Its set up for around 8 psi. I have a fuel regulator and 70mm throttle body but do i need a larger fuel pump and injectors for this as well and do i also need a timing control system. thanks
You'll definitely need bigger injectors and fuel pump. I'm thinkin a 255 lb/phr pump, and some 42 lb injectors with a tune. I think you can use some 30 lb injectors with an FMU (fuel management unit) but from what I've heard the 42 lb and tune is the way to go. Also, the Powerdyne, are you getting it cheap or something, cus they're not the best superchargers out there. If you're buying a new one, look at superchargersonline.com, and check out their Vortech units. That's what I'm gonna roll with one of these days. Good luck man
