supercharger question
  • Thread starter Thread starter tendo
  • Start date Start date Dec 19, 2003
T
tendo
86
  • Dec 19, 2003
I was thinking about saving my money and gettin a 10 or 12 psi charger but wasn't sure. Where does it mount? From the pictures ive seen it seems to be where my altinator is right now. What is the FMU? Would my holley 600 be ok to use on 10 psi? What problems should I watch out for while using a supercharger? Im just looking for general info to get me goin on it.
Here are my specs:
84 Four eyes
302 stock rebuilt heads/ rebuilt motor, holley 600, edelbrock rpm intake, MSD 6AL ignition, MSD distributor, bbk equal length chrome headers, off road H pipe with resonator, KYB all 4 corners, tremec 3550 pro 5.0 shifter, auto-spec clutch, 235/50/16's =)
Thnx
C
custom89stang
705
Seattle, WA
Dec 19, 2003
  • Dec 19, 2003
dont go above 9 PSi with an engine without re-enforcement (ie: forged pistons)
SmockDoiley
1,591
San Diego, CA
Dec 19, 2003
  • Dec 19, 2003
Well procharger, which is the cheapest when doing a carbureted blowthrough setup, mounts it where the A/C is. You can either keep the A/C or get rid of it, and it you want to save the powersteering you can relocate it with a kit from them. Do you have forged pistons in that thing, and what is your compression ratio. I am currently running a 14 lbs Procharger in my 342 with forged internals in my 85 Mustang. Talk to extreme velocities about a carb hat cause you dont need that whole carb enclosure. You also CANT use a Vacuum secondary carb which I'm sure yours is unless you changed it. Go with a 650 to 700 double pumper. You can run 10 psi safely as long as your bottom end is good. Make sure you have either hyper. or forged pistons and a main support. That should be good enough, and the best part is the atomization from the carb acts like a mini intercooler which can cool the air by as much as 50 degrees. You also have to modify the carb if you do this setup. It needs nitrophyl floats, and you need to mill off the choke setup. Hope this gives you a good idea of what to do. Scot Rod
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
F
1993 Cobra flooding
  • FireFoxCobra_SVT93
  • May 20, 2022
5K
Fox 5.0 Mustang Tech Mar 11, 2023
nickyb
