  • Special Production
Roush Superchargers
  • Thread starter Thread starter 98 Saleen Cobra
  • Start date Start date Sep 12, 2005
98 Saleen Cobra
340
Campbell, Ca
Sep 12, 2005
  • Sep 12, 2005
Hey guys I have a few questions. My Saleen has a Vortech S-trim V-1 supercharger right now and has a 6lb pully with a Andersen powerpipe, all and all it's putting out 9lbs of boost. Right now it's putting out 470rwhp and 485 rwtq. I want about 600rwhp and 600 rwtq. So my question is can I achieve this with my current supercharger, safely???? Or should I just upgrade to a T-trim charger??? And would this conflict with the Robert Yates Racing heads that I have on it??? I already know that I would have to upgrade my fuel lines and such but it sure would be nice to just upgrade the pulley. Thanks
Chris
S351R"Animal"
20+ Year Stangneter
Dec 3, 2002
708
Manhattan, KS
Sep 12, 2005
  • Sep 12, 2005
I would recommend going with the T-trim. Which motor does your car have? Its kinda confusing with the heads you listed. To make 600 rwhp be ready to go into the short block and replace the rotating assembly. For the fuel system you will be pushing the stock system even if you upgrade the rails. The rails that run for the tank to the the engine back may have to be upgraded. I did mine at one time along with a sumped tank and twin aeromotive pumps. I made more than 600 but once you pass a certain threshold the cost isn't that different.
98 Saleen Cobra
340
Campbell, Ca
Sep 12, 2005
  • Sep 12, 2005
well I have a 281 4v cobra motor. With head work done to it. I know that I would have to replace the fuel lines and rails and probably injectors but as it is right now I have 42lb injectors. But I did my research and it said that the 4v motors in 98 were good for around 800hp
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
