  • SN95 4.6L Mustang Tech
Superchip Microtuner
  • Thread starter Thread starter 03gtmustang
  • Start date Start date Mar 22, 2004
03gtmustang
923
Northern Va
Mar 22, 2004
  • Mar 22, 2004
I bought the Superchip Microtuner a little while ago and have used it to tune my shift points, shift pressure, gears, and octane gas. I was wondering if by changing it from 87 to 93 octane advanced my timing at all?
JonJon
4,801
back in Marylands
Mar 22, 2004
  • Mar 22, 2004
I'd imagine that's exactly what it did.
03gtmustang
923
Northern Va
Mar 23, 2004
  • Mar 23, 2004
The reason I ask is because Im thinking about a NOS dry kit and they recomend not advancing the timing because it could cause detonation. They also recomend using 92+ octane, but our stock chips are programed for 87. What should I do?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 23, 2004
  • Mar 23, 2004
If you spray program it back to stock , then run 93 only while jugging. If you arent spraying its ok to run the timing up but always keep 93 in it .
03gtmustang
923
Northern Va
Mar 23, 2004
  • Mar 23, 2004
So even though I program the superchip for 87 I can still put 93 in with no problems?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 23, 2004
  • Mar 23, 2004
yea it will be fine , just get in the habit , you dont wanna forget one time and pull up and chunk 87 in it if you got a full bottle and plan on using it , or have the timing up and forget and fill up with 87 . You wont notice any difference unless you put 87 in and spray or set the timing up .
03gtmustang
923
Northern Va
Mar 23, 2004
  • Mar 23, 2004
Alright, thanks guys.
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
wyatt-tetro891
W
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
