Just wondering if anybody knows if a 91 t-bird supercoupe manual will swap into the place of my 87 5.0 T-5. We put a turbocoupe trans in my friends fox and it worked great, but im not sure if the supercoupes are different, thanks.
trendkilllx said:Just wondering if anybody knows if a 91 t-bird supercoupe manual will swap into the place of my 87 5.0 T-5. We put a turbocoupe trans in my friends fox and it worked great, but im not sure if the supercoupes are different, thanks.
tb9050lx said:the tranmissin in tthe sc is a mazda and wont work in your fox .the t-5 is completly diffrent , it would bolt up but the clutch is hydralic instead of cable operated and i dont think the mounts for the tranny would work.
monsters said:The shifter box is about 6" too far back. And yes they still do make parts for them, that trans was put in 5-speed f150's broncos rangers and bronco II's for years although its name was changed a few times. Started out as a M5OD and had brass syncros and an 11" clutch. The super coupe 5 speed is a M5R2 (Manual 5speed revision 2) which had fiber synchros and could withstand more abuse than a standard T5 which is why they put it in the SC. A stock SC's dry weight is about 3900lbs and the engine puts out 325ft lbs. of tourque (in 94-95) and actually the 3.8 SC had 5 more hp than the 5.0 mustangs in thier best years. The M5R2 is a good trans, as long as you maintain it. It just wont fit in a mustang.
You are thinking of a turbo coupe, which uses a T-5GearHd6 said:Im pretty sure a friend of mine put an SC 5spd in his 85 Capri and it worked fine but was geared way to low internally for the 5.0 it worked good in the SC because it kept the RPM's high for the turbo 4 cylinder.
let,s just agree to disagree. What is your screen name on the SCCOA maybe I will see you there sometime. Mine is the same "curse" member since 2001.
