Surface Rust on Connecting Rods
  • Thread starter Thread starter duo_z
  • Start date Start date Oct 3, 2010
duo_z
78
  • Oct 3, 2010
Is a little surface rust going to hurt anything? My project block was sitting for a few months waiting for some parts and some of the connecting rods got some rust on them, will this cause any problems? Should I try to clean it off?
rbohm
6,698
550
204
tucson,az
Oct 3, 2010
  • Oct 3, 2010
it wont hurt anything. clean it off if you like though, but use a chemical rust converter if the rods have already been prepped to avoid creating stress risers.
G
gr8one
52
Ft. Meade Polk Co FL
Oct 3, 2010
  • Oct 3, 2010
i would use ospho on it (rust converter). you can get it for $22 at ace hardware.
duo_z
78
  • Oct 5, 2010
Ok, thanks for the replies. I'll have to pick some up later.
K
KStang65B
18
  • Oct 5, 2010
Home Depot has Gallon jugs of Phosphoric Prep & Etch in the paint department for under $15. I use it on all my rusty parts with excellent results.
G
gregski
577
Sacramento, California
Oct 7, 2010
  • Oct 7, 2010
Phosphoric acid from Home Depot removed all the rust off my roof, however afterwards you have to neutralize it with baking soda and water and then wash it off with soap and water, otherwise it will etch the metal and leave a nice white coat/film on the part, not ideal for an internal part, I would wash the heck out of it after then dry it off and spray it with WD-40
could you use a wire wheel to take the rust off, would that damage the rods?
D
D.Hearne
11,730
south louisiana
Oct 7, 2010
  • Oct 7, 2010
I use a wire wheel for anything like this. I keep one on one side of my bench grinder. It removes the rust and burnishes the part's surface.
rbohm
6,698
550
204
tucson,az
Oct 7, 2010
  • Oct 7, 2010
one thing, if a wire brush is used to clean off the rust, make sure that you run it length wise along the rod to minimize any stress riser formation that will weaken the rod.
D
D.Hearne
11,730
south louisiana
Oct 7, 2010
  • Oct 7, 2010
K
KStang65B
18
#10
  • Oct 7, 2010
  • #10
Glass bead blast followed up by shot peening.
duo_z
78
#11
  • Oct 15, 2010
  • #11
So if I would fog the inside of the engine with the rotating assembly installed using ospho would it do any harm? Sorry I forgot to mention the rotating assembly was installed.
D
D.Hearne
11,730
south louisiana
Oct 16, 2010
#12
  • Oct 16, 2010
  • #12
Don't know what you mean by "ospho" but if it's any kind of chemical stripper/cleaner.....................NO !!! Leave the rods as is and give em a good coating of motor oil.
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
E
New Member with 91 foxbody
  • EricMac13
  • Jul 22, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2025
EricMac13
E
