Surging 88'
slo88
12
Iceland
Yesterday i installed a new set of injectors on my 88, 19lb. After the install, it surges violently and i don't really have a clue as to what i can to to fix the prob. I am military, and currently stationed in Iceland, ( that means no good shops in site, these guys have never seen an 88). The question i have is since i don't have a mass air meter, is there anyway i can "reboot" the computer in the car to get this squared away? thanks
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems. The first post has all the updated answers.
if you pulled the upper intake and replaced the injectors, make sure you do not have a vacuum leak - check all the injector o-rings on the intake side and see if your intake gasket is OK. Make sure the vacuum line to the MAP sensor is hooked up and air-tight.
