Ok here it is, I just replaced the Heads with GT40P with 1.90 x 1.60 valves, TFS Stage 1 camshaft, Professional Products Typhoon Intake, 24lb injectors, 255LPH fuel pump, Adj. fuel regulator (Pressure set to 32PSI with the vacuum line off and jumps to about 37 with the vacuum line on), Autolite 764 plugs gaped at .45, FRPP 9mm plug wires, FRPP cap and rotor, TFI module and 1.6 roller rockers. I am running a 65mm Throttle body and the TPS is set to .98 volts. I am also running a C&L Mass Air Meter with the coreect 24lb sensor. Car runs will strong and has dynoed over 300 HP... The problem I am having is the Idle. Sometimes it is fine and idles at about 950 RPM then I put it gear and drops to,about 750-800 RPM and is fairly smoothy. Then sometimes it will idle at about 1100 RPM will kick up to about 1500 when put in gear. I can actually put it in gear and not touch the gas and it will idle at 1500 rpm and move the car down the road at 25 mph... I am at a loss... When it does idle right it runs smooth as silk and has a lot of power and throttle response. When it is not idleing right it is very sluggish with hesitation in the throttle.
Does anyone have any suggestions for me, this is driving me bannanas...
