  • 1994 - 1995 Specific Tech
Surgy clunky 95
  • Thread starter Thread starter Fopar
  • Start date Start date May 19, 2007
F
Fopar
178
San Marcos, CA
May 19, 2007
  • May 19, 2007
Well I got this 95 I bought running, it had a small engine fire and needed some wiring but all has been fixed now. The previous owner had the heads rebuilt before the engine fire and supposedly ran good. It appears they did a few mods, I noticed some under-drive pulleys, different exhaust and I thought I heard something about a chip so possible ECU work.
The car runs real strong but down in the low RPM it bucks and surges a bit, definitely does it more with heavy load and in the lower RPM range, above 2K its pretty smooth but will still buck a little. Down below 2 it hates it if you give it more than 1/4 throttle, bucks etc. It has a new CTS, and a stock throttle body off another mustang with corresponding TPS and IAC, they seem to be working alright as the car revs clean and idle works decently. Oh and I think the PIP is good, like it said it runs clean in the upper RPM band and revs cleanly. Also plug wires/cap/rotor are brand new...
I do have a decent running 94 5.0 5spd car as well, and today I put the intake tube with MAF and IAT off that car on this one to see if it was a MAF problem. The bucking cleaned up a little but the car was totally flat, alot less power all over the place... and the bucking was only maybe 40-50% better (which may only be a result of the lack of power). So I'm wondering if the MAF that came with the car was tweaked for whatever mod(s) they did to it. Check engine light isn't on, and I know it works as I'd pulled the vacuum line off the EGR to test something and drove it and it lit it up....
On another possibly related note when the car bucks you can feel a clunky crunching in the chassis, sometimes feels like it's in the rear, sometimes trans, sometimes up front . I had the car up in the air and was crawling all under it today checking mounts etc. Rear bushings etc looked good, trans mount looks good, motor mounts didn't seem to be too bad . I did find the passenger side axle has little bit of radial play, so bad axle bearing on that side but it wasn't way out . Took it to a friends trans shop and he drove it, he says he thinks the rear is trashed that the carrier/spiders/cross shaft is messed but I don't think it'd cause what i'm feeling. The rear makes no noise as far as whining so i'd bet the gears are fine and the limited slip seems to work well.
I figure the bucking could be the motor or it could be the rear or trans binding.... but like I said it only seems to happen in the low RPM band . Any ideas?
F
Fopar
178
San Marcos, CA
May 19, 2007
  • May 19, 2007
F
Fopar
178
San Marcos, CA
May 19, 2007
  • May 19, 2007
where's all the tech experts? I thought this was a 94-95 mustang forum?
F
Fopar
178
San Marcos, CA
May 20, 2007
  • May 20, 2007
crapola
C
cbarr300
746
goose creek, SC
May 20, 2007
  • May 20, 2007
same thing happened with mine....I have a cam and 42 lb/hr injectors though...
maybe he did head/cam work
Also, I don't think this is your problem...but bucking is oft times caused by having too much low load timing.
does it only do it when you're off the throttle. And if so, does it clear up when you press the gas?
F
Fopar
178
San Marcos, CA
May 21, 2007
  • May 21, 2007
No it only does it when i'm on the throttle..... 1/4 throttle or more below 2k mostly.
Thanks for the reply .
F
Fopar
178
San Marcos, CA
May 21, 2007
  • May 21, 2007
bump
C
cbarr300
746
goose creek, SC
May 21, 2007
  • May 21, 2007
well...sir..I'm sorry, but I'm at a loss here lol.
I've heard of people having issues like this fixed by "clocking" the maf. Basically make sure it's at 12 o'clock (I think that's where it should be).
Also, one thing you might want to check is your fuel system. You said it runs fine at top end...so I don't really think it's your problem....just my next best guess.
try running some fuel system cleaner through your system.
OH YEAH, you may have already done this...but have you checked for codes? I'd run a cylinder balance test and see if something is screwy.
sorry I couldn't be of much help
good luck
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
