Suspension advice..
FoxatHeart
Show Me Your Headlights
Saginaw, Mi
Ok, so now that I've got the fox (87 GT).. I want it to be more driveable before I start on the body work..
My list isn't long, but its filling up.
5.0 runs great, drives great, but the ride.. Well, let's say the ride is less than desirable!
Was wondering what shocks/struts you like best? What ride best?
I can't afford top of the line, but I'm not looking for the cheapest ones either.. Please remember this is a work in progress! Haha
What are the symptoms of the car? Is it hopping or excessive bouncing? Are the tires wearing uneven? Have you narrowed the problem down to the shocks before you start throwing parts at it.Also, what kind of ride are you looking for- stock replacement, upgraded performance? Is this a daily driver or street strip?
I had Taco Bell for lunch- 3 Cool Ranch Doritos and a Dr. Pepper.
Just the way it sits, you can tell the shocks are pretty shot. (Even with really worn original struts, my Saturn rides better!)
Its a stiff ride, a lot of bouncing.. Tires are in great shape, handles well..
It's a daily driver.. This girl isn't looking to race her! Haha
Just need a more comfortable ride.. probably prefer to go with something better than stock.. I want to drive the hell outta this car!
Bare with me, this is my first rodeo.. No doubt many of dumb questions to come in the future!
Lunch here is homemade meatball subs.. ;)
And my daughter would prefer nacho cheese dorito tacos.. Haha
Just go with a good set of KYB or Monroe replacement shocks, struts, and quad shocks. If you want to spend some money, go with Tokico blue colored shocks, struts. I guarantee that you will also need to address worn components such as sway bar bushings, control arm bushings, etc. Once you put new shocks on, it will make the old worn parts more noticable. You will also need to get the car aligned after the struts install.
MOM WHAT'S FOR LUNCH?????
Reactions: FoxatHeart
If u make it to bushings, i would stick to stock style rubber bushings. Ive had both and enless u like getting shaken on every little crack/hole in the road I would stick to rubber. The poly ones are great if u are driving on perfect roads, and they take turns on rails but for every day driving I would stick with rubber. KYB are good replacements shocks struts, Ive been running them about 10 years now.. The first 2-3 were as daily driver
If you don't want anything too aggressive, keep it simple.
I've got stock cut springs (just half a coil) and Tokico Blue's all the way around and a set of poly swaybar bushings and end links. Car handles great, yet remains very forgiving on bumpy roads. Don't forget the chassis. Sub frame connectors, are a must. I took it a step further and went with jacking rails too. Car is solid as a rock and now really lets the suspension do it's job instead of transferring everything through the body.
I've got a set of rear upper and lower control arms ready to go in this spring.
