Suspension and traction issues
demononwheels
10
Texas
For those making 500hp + or not
First of all, I’ve already searched the forum.
Just put a new motor and Vortech s-trim
http://amarilloracers.vidiac.com/toprated/0/wm/2DF795CC-3824-4C4B-B691-40B226B8B0B8.htm
in my 1993 mustang Lx. I made 508 hp and 508 torque to the rear wheels.
Can’t get any traction. Duh. I’ve got some MT ET streets 28x10.50x15. And that’s pretty much it for traction.I'm doing a decent burn out. The reason I went with street slicks is because of the stock axles.
I tried a few ¼ mile runs today. Best top speed was 109 with a bunch of traction loss. If I leave off the line at low rpm, it laggs. To high, lose traction in first and second gear.. Running 16 psi in the tires. The guy I bought this car from told me that it has suspension springs out of an 1993 4 cylinder stang.
What suspension parts to I need to buy for the front and rear?
I just need to know where to start and want to buy. I dont want to go back and ugrade the suspension later.Any tips? What rpms to launch at?
With that much power upper and lower control arms are a must. Torque box reinforcements, new axles and welded axle tubes should top your list also. A good set of lowers can improve your traction problem greatly and adjustable uppers to set the pinion angle should be a must to help keep it planted to the ground. What is your current 60ft.?
60ft time? Don't know. What do you think it should be? Our local track closed down. I'm waiting on my new SS
G-Tech.
Exactly, what parts are you recommending? Upper and lower control arms? Torque box reinforcements? New axles?31 spline moser? I guess I'll have to purchase a new differential. I'm new at all of this and their isn't a whole lot f local help around here.
Thanks for your help
G-Tech.
You can upgrade the axle's to Moser or Strange and keep the stock Differential if money doesn't allow for a auburn or Eaton Diff. with 31 spline axle's.
They make 28spline units with the C-clip's.
I would recomend Maximum motorsports or UPR for your control arms. :D
For your torque box reinforcements go to RHN performance website or while you're on this site P.M. Rick 91GT. He'll hook you up!:nice:
first thing i would do is lower your psi in the tires. try 14psi then 12 then 10. i have a lakewood traction action rear uppers and lower control arm set up with sucky kyb struts and shocks and ford racing progressive 650lbs springs. I have banged off 1.60 sixt foots launching on my juice. on not so stick tracks i always get low 1.8's or high 1.7's.
sunil6784 said:
What kind of block do you have thats making all this power?
Here you go man. This is my engine combo.
306
8.5:1 compresion
Valley Girdle
race preped stock crank and rods.
SRP forged pistion.
DSS Main billet girdle.
X303 TURBO Swirl aluminum heads(out of the box.)
1.6 fms aluminum rockers.
42 lb injectors
Comps custom grind cam for superchagers XE274HR.
stock fuel rails
trickflow hardened pushrods.
intank holley 255lph fuel pump
T-rex in-line fuel pump
gt-40 upper and lower(out of the box)
msd pro billet distributor.
BBK 1 5/8 shorties
76mm C&L
75 MM ACCUFAB
msd BTM box
Vortech S-trim with 12 psi pulley.
Tuned with SCT programmable switch chip.
Anderson power pipe
Made 508hp and 508 torque at the rear wheels. Est 602 flywheel hp
I have a Snow Performance Stage 2 meth/h2o cooler for added insurance I haven't
yet installed. Still looking for a good Tuner.
