suspension geometry and steeda lowering spring
Killnboy
26
What will happen to my suspension if i add steeda sport lowering springs to my car, i already have casting chambers in my front. What will be effected with this? What other mods would i need to buy, shocks. I was thinking maybe new ones since it would be more compressed. IDk someone please help my friend is selling his for cheap and their brand new. Thanks james.
Lowering springs will help the car handle better but you will be at a loss for weight transfer (F/R weight transfer). By casting chambers, I assume you mean caster/camber plates, and it would probably be a good idea to score a new set of them since you don't know the quality or age of the others. New shocks are not necessary, but they do help out tremendously in the ride quality. You will also need to get a new front end alignment when you lower the car. The front tires tend to bow inward causing a very uneven tire wear pattern, and causes your tires to wear about 3 times as fast.
Joe
