i am having a constant issue with myy front suspension on my 68. the front suspension seems to be binding and getting stuck either way to low or way to high. now i have taken everything part several times and have found no binding anywhere period. if the car is parked it sits at normal ride height if i drive it..it will get stuck real high after a bump or so,
once i hit the brakes hard it will move back down and stay until the process repeats itself (hit a bump, or turn). recently i have removed the shocks just so see how everything moved while driving and it right away got better. it still does bind but not nearly as bad and takes less to get it to re-settle. i have rollerized spring pirches installed and im woundering if they are at fault because theres to much force on them to pivot back and forth unless i brake real hard like i have been doing to force them to move? keep in mind shocks,control arms,sway bar move with ease when dissasembled. any help would be great thanks!
