SVO ebrake
  • Thread starter Thread starter 50gt1988
  • Start date Start date May 24, 2005
50gt1988
154
Spanaway, WA
May 24, 2005
  • May 24, 2005
I have a 86 SVO rear disk brake setup on my stang but since I installed it I've never had an emergancy brake. I was told that you need an ebrake to reset the ratcheting mechanism in rear brake calipers and that it needs to be pulled at least once a day. Does anyone know if this is true? If it is, does anyone know how the ebrake is setup on an 86 SVO?
50gt1988
154
Spanaway, WA
May 24, 2005
  • May 24, 2005
ttt
M
mikeflys1
217
CT
May 24, 2005
  • May 24, 2005
Thats only if you use the conversion kit with the gm calipers. As far as i know no ford calipers have been like that.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
  • May 25, 2005
You should probably have an E brake for safety reasons if anything!
50gt1988
154
Spanaway, WA
May 25, 2005
  • May 25, 2005
Well thats why I'm trying to hook it up but I'm missing a part because I have no way of hooking the cable end to the arm on the caliper.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
  • May 25, 2005
Do you have the correct cables?
50gt1988
154
Spanaway, WA
May 25, 2005
  • May 25, 2005
I have 86 svo cables.
txstang84
1,639
42
69
Tuscola, tx
May 25, 2005
  • May 25, 2005
where did you get the cables from? i just did that swap, and bought the cables from advance auto parts...they came with the correct clevis installed
...i do have a slight problem though, I think my right rear caliper is hanging, and upon looking at my service manual, it says to loosen the "caliper end retainer"...what the hell is that? i see two caliper bolts, and a parking brake lever. it goes on to say that i need to "screw" in the pistons to seat them otherwise the parking brake section of the caliper will be messed up and the caliper will need to be overhauled.
any advice?
50gt1988
154
Spanaway, WA
May 25, 2005
  • May 25, 2005
well for these calipers the pistons have to be screwed in. I just bought a tool that attachs to a wrench. Can you send me a pic of what your emergancy brake connection looks like??
txstang84
1,639
42
69
Tuscola, tx
May 25, 2005
#10
  • May 25, 2005
  • #10
you mean you want to see the connection from the cable to the caliper, right?
50gt1988
154
Spanaway, WA
May 25, 2005
#11
  • May 25, 2005
  • #11
yeah
txstang84
1,639
42
69
Tuscola, tx
May 25, 2005
#12
  • May 25, 2005
  • #12
i just thought about something, do you already have your ebrake handle modified for the rear discs?
50gt1988
154
Spanaway, WA
May 25, 2005
#13
  • May 25, 2005
  • #13
No, I haven't gotten to that yet, I've been trying to get the cables hooked up first.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brakes Need help ID’ing which brake lines and seals I need
  • AnthonyA1234
  • Apr 2, 2025
Fox 5.0 Mustang Tech Apr 14, 2025
limp
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
L
05GT brakes on a 98GT?
  • lparsons42
  • Sep 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2025
lparsons42
L
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
