Swap headers not working
Im having problems with my MAC longtube 315W swap headers not fiting in my car. The headeron the drivers side hits aginst the steering knuckle shaft and wont let the motor drop onto the mount bracket. Im having about an inch or so before the motor will sit on the mount bracket. Has anyone had this problem before? If so, how did you fix it? Thanks
Depending on how things are sitting right now, it may be easier to break the steering linkage loose, rather than raising the block back out. You are the only one that can answer that though.
Good luck with the headers,
jason
If they are anything like my swap headers, i had to disconnect the steering rag joint because it slides between two header tubes. This may not be the case with yours, but if i can fit my 460 swap headers in while the motor is in car, im sure you can put the 351 swap headers in while yours is down in the car too.
