I have an 02' GT. I recently swapped brakes with a friend with an 03' Mach. He wanted my smaller brakes so he could run skinnies up front.
Ok on to my brakes. We put them on, bled both sides and still had NO pedal feel. So we took the calipers apart and fully compressed the pads and put it all back together (as the pads were not gripping before). We again bled the brakes some more and yet again my brake pedal has no feeling what so ever - however the brakes do lock the rotor somewhat, they will stop it from spinning.
So we did some research and decided to bleed the Master Cylinder - we used the front bleeder screw. Even after this attempt I still have NO pedal feel. The pedal goes straight to the floor without any resistance when I start the car.
So what can we look at next for a problem.
Another problem we noticed: when bleeding the brakes, hardly any fluid was coming out - just a little bit with no air. After bleeding BOTH sides the Master Cylinder NEVER went empty. Not much fluid was moving out.
So what would cause this, what should we look at? And is there any other bleed valves on the Master Cylinder?? When doing a search on here, some people mentioned more than one - but there were no specifics.
Thanks for the help!!
