swapping to a 5-speed...
Well, it looks like a t-45 swap will be forthcoming since the AODE/4R70W in the wife's 96 coupe is acting up.....AGAIN :bang:
Here is a list of what I know I will need for the swap...anything I'm forgetting?
Tranny
Bellhousing
Clutch Set
Shifter
Shifter Trim Boot
Shifter outer boot thingy (the thick rubber piece that seals the floorpan)
Pedals Assy
Cable/Quadrant
Clutch Fork
ECM
Trans Wiring Harness
Driveshaft
Will the crossmembers be the same or do they require a swap? Also are the speed sensors the same or no?
And are there any tricks or shortcuts or aggravating problems I should know about?
Thanks for the help! :nice:
i did the conversion...
i would suggest you push the floor pan up from below the car while the tranny is still outside the car
the manual floor pan is actually higher than the automatic and the shifter will touch with the hole for the shifter... i had to trim the hole and shifter boot, because it was starting to be annoying... resonance
what part of the floorpan are you talking about? where the shifter comes through or further down than that?
thanks for the tip though!! :nice:
tarch said:
nope... you need that too... but to my understanding it would come with the tranny... at least mine did :shrug:
nah, this one won't...it's one I'm buying from a buddy
2k miles, clean bill of health from a local tranny shop, $150. It has a small hole in the case from a piece of metal in the road, but can be fixed with aluminum welding :nice:
