2000 3.8L stock. One of the sway bar bushings is busted. Tried to order but there are a couple different sizes out there so trying to see if anyone knows the exact one.
Stock is 25mm. Too bad- I had a stock V6 bar with the bushings just a few months ago, but threw it away- you could have had the bushings for free!
I would recommend if you're pulling the bar off anyway, get a set of GT bars (front and rear). The V6 doesn't even come with a rear bar stock, so adding one will help your handling and help locate the rear axle (stops the car from wagging its rear end when cornering on a bumpy road). The GT and Bullitt sets are larger diameter in the front (and come with bushings) so they'll improve your handling.
