Sway bar issues
  • Thread starter Thread starter ADub64
  • Start date Start date Aug 22, 2005
A
ADub64
47
Houston, TX
Aug 22, 2005
  • Aug 22, 2005
I am trying to finish up rebuilding the front suspension on the car. Used new stock style parts with a 1" sway bar and 620 springs. I went to install the sway bar (springs are not installed) and the sway bar hits the frame during travel. I cannot figure out why. I bought the kit from Laurel mountain mustang and their tech sppt had no suggestions other than to check the p/ns and make sure I received the appropriate part. The only thing that looks possible to me is that the end link are too tall, but I don't have the originals to compare to. Has anyone else had this issue?
AW
red65
411
Ann Arbor, MI
Aug 22, 2005
  • Aug 22, 2005
Just had the same issue this weekend when I put two passengers in the car with me for the first time since its 'rebirth.' The front suspension compressed enough that the sway bar was able to contact the outsides of the frame rails. It made a load squeaking sound - while not particularly damaging, it was embarassing as all get-out since I was at the Woodward Dream Cruise! :damnit:
Anyway, I solved the problem on Sunday by shortening the links that attach to the lower control arms. I removed about 1/4" from the spacers on both sides (the steel tubes that space the upper link bushings from the lower ones), and ground a modest amount more clearance in the notch on the frame rail. This lowered the sway bar just a bit and left some space between it at the frame rail. Between shortening the end links and the clearance grinding, it doesn't appear possible now for the sway bar to contact the frame. It took all of an hour and shouldn't have any negative effects on handling, durability etc...
A
ADub64
47
Houston, TX
Aug 22, 2005
  • Aug 22, 2005
I purposely wanted to install the entire suspension before I installed the springs so I could easily check for binding. I had approximately 4" of upward travel left when the sway bar contacted. Not sure 1/4" would work in my case. Maybe more like an inch? Can end link height affect the sway bars performance?
19stang66
689
  • Aug 22, 2005
You both should post some pictures as I just installed a 1" aftermarket sway bar from American Pony. But i havent had my car on the ground yet so Im not sure if it hits the frame. If it does it sounds like an easy fix.
A
ADub64
47
Houston, TX
Aug 22, 2005
  • Aug 22, 2005
Good idea, I will take some pics next time I am under the car
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Aug 22, 2005
  • Aug 22, 2005
Yes, please do. I just ordered that over the weekend.
red65
411
Ann Arbor, MI
Aug 22, 2005
  • Aug 22, 2005
The spacer tubes on mine were only about 1.5" to start with (1-1/8" bar from NPD - don't know the manufacturer off hand), so I'd be a little wary of shortening them an inch. Because of the motion ratio (suspension to sway bar) you'll get more benefit than you might initially estimate from a short reduction on the sway bar link - i.e. you don't need to shorten it an inch to pick up an inch of clearance... Easier to make small cuts than to add back on!
R
race-rodz
44
  • Aug 23, 2005
i have/had 620 springs w/ 1 coil whacked, shelby uca mod, 1" swaybar from mustangs plus. i shortened the endlinks about 1/2" never had any problems with clearance even with car load of people and "spirited" driving.
A
ADub64
47
Houston, TX
Aug 25, 2005
  • Aug 25, 2005
Got out and played with it some last night. Ground down about half of the lip on the frame and cut about 1/2" off the spacer, but it was too late to go get new bolts. Is it ok to ground the lip flush to the frame or should I leave some meat there?
A
ADub64
47
Houston, TX
Aug 25, 2005
#10
  • Aug 25, 2005
  • #10
So did the 64 1/2s have a different front subrame? I looked at 19Stang66's pics in his disc brake thread and the lip along his frame rail is like 1/3 of the size of mine. The 64 1/2 has a much wider lip and a notch cut in it for the sway bar. This seems to be my problem. Wish I would have taken pics last night.
AW
R
race-rodz
44
#11
  • Aug 25, 2005
  • #11
mine is a 64 1/2... didnt enlarge the "notch" at all
A
ADub64
47
Houston, TX
Aug 25, 2005
#12
  • Aug 25, 2005
  • #12
No idea, I opened the notch up by about an inch and a half, cut 1/2 inch of the sleeve. It fits now, Im done with it
F
Sway Bar Endlinks
  • Fri Guy
  • Jun 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2025
Fri Guy
F
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
Rear sway bar popped off
  • Creomod
  • Jan 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 16, 2025
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
SN95 Sway Bar Endlink Issues!
  • Swizzy
  • May 10, 2024
1996 - 2004 SN95 Mustang -General/Talk- May 13, 2024
Swizzy
