I'm having problems with my sway bar. 3 weeks ago I had the car up in the air, and noticed that my Sway bar had eaten into my shock absorbers. I've got TCP coil overs (VariShock) and a 1 1/16" Sway bar. So now I've trimmed of the edges of the sway bar, and gotten new poly end links with the lower 0.78" (2 cm) high spacers. (However, they still touch the shock absorbers. With out the spacers on the end links, it does clear. Can a sway bar be mounted like that? Or does the end links have to be there ? Can the Sway bar be mounted upside down? (Under the LCA)
Here are some pictures of the shock damage.
I'm still waiting on a reply from the TCP tech support if the shock absorbers are repairable.
) then fit everything and lower the car while watching it through the entire range of motion. Make SURE you cut both the same length - maybe set them both up in a vise, or cut one and use it as the template for the other. Repeat until it clears totally.
