Sway bar
  • Thread starter Thread starter ADub64
  • Start date Start date Nov 13, 2005
A
ADub64
47
Houston, TX
Nov 13, 2005
  • Nov 13, 2005
I posted a few months back when I redid the front suspension. Had issues getting the sway bar to fit. Well I got underneath it today to work on the steering and saw rub spots, so I removed the sway bar. When I took the sway bar off, I set the car back on the ground and noticed the ride height is about 1.5" higher. So the sway bar is binding the suspension and not letting it flex down. The only thing I can think is that I was sent a sway bar for a 67. The current sway bar bolts into my 64, it just doesn't fit as designed. Does this sound possible?
latamud
791
Tampa, FL
Nov 13, 2005
  • Nov 13, 2005
Drive the car around the block and it will settle back down.
Where was the sway bar rubbing? Pics? I don't think the 67 sway bar would be a significant problem in a 64.
A
ADub64
47
Houston, TX
Nov 13, 2005
  • Nov 13, 2005
The car has been driven plenty sense the original installation. The sway bar is rubbing badly against the frame on both sides. I had this problem at installation, but I cut the spacer down on the end links and it fit. After some miles, it is easy to see that the sway bar is still rubbing the frame. My comment about the ride height was that without the sway bar attached, ride height is higher, the sway bar should not affect ride height. Also, I found the p/n on the bar and it is marked for a 64-66 Mustang. I'm lost on this one.
rbohm
6,698
550
204
tucson,az
Nov 13, 2005
  • Nov 13, 2005
sounds like you might have installed the bar upside down. it can happen easily, in fact i have done it.
P
PJx5x
197
Chicago
Nov 13, 2005
  • Nov 13, 2005
when latamud said drive it around the b- i think he meant without the sway bar and see if it settles back down without it
A
ADub64
47
Houston, TX
Nov 14, 2005
  • Nov 14, 2005
Didn't install it upside down. I installed it with the elbow pointing down. 19stang66 posted some pics of his front end a while back, I verified it is installed in the correct orientation.
bnickel
5,640
lubbock, texas
Nov 14, 2005
  • Nov 14, 2005
if they sent you a 67-up sway bar it could very well have the probs you are describing. the 67-up sway bar is wider than the 65-66 bar. also do you have granada spindles? that could be a problem as well, but usually the ride hesight will go up and stay that way while you are driving.
A
ADub64
47
Houston, TX
Nov 15, 2005
  • Nov 15, 2005
I have stock drum brake spindles. I compared the measurements of the sway bar I have to one they have in stock and its the same bar, correct part for my car. Why is it such a difficult fit?
AW
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
Rear sway bar popped off
  • Creomod
  • Jan 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 16, 2025
limp
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
SN95 Sway Bar Endlink Issues!
  • Swizzy
  • May 10, 2024
1996 - 2004 SN95 Mustang -General/Talk- May 13, 2024
Swizzy
