Sway Bars?
  • Thread starter Thread starter myfirstii
  • Start date Start date Dec 12, 2004
M
myfirstii
401
chicago,Il.
Dec 12, 2004
  • Dec 12, 2004
What size are the stock front and rear sway bars? Also how easy is it to find rear end links for it, cause My II didnt come with a rear sway bar.
thanks for the info,
Pat
1badII
796
Durham, North Cacalaky
Dec 12, 2004
  • Dec 12, 2004
When I got my rear sway bar from PST, it came with an L bracket to mount traditional end links to it. You will need a longer bolt, though. For some reason the one included is too small. You will probably also need to get new spring plates with perches for the bushings. It came with some brackets to bolt the sway bar to the rear end housing, but they would require modifying the hard brake lines, and they may move the bar too close to the housing. I only test fitted it, and those brackets gave me those problems, so I decided to wait till I order some Cal-Tracs.
78CobraII
Moderator
Jul 31, 1998
1,808
Birmingham, AL
Dec 15, 2004
  • Dec 15, 2004
The rear swaybar end-link mounts are pretty much going to have to be found used. The endlinks also. I'm goint to try to get a replacement bushing for the body side. I was able to use standard end link bushings for the swaybar side.
Vince "The Fabricator" that used to post here a lot made a small batch of the body mounts up a few years ago. With the proper dimensions it should not be a big deal...especially if you don't mind using spherical rod ends on the body side.
The rear spring plates with the mounts for the swaybar will also have to come from a junkyard.
This is one project that is definately worth doing...especially if you are going to use the larger rear swaybar and poly bushings all around.
jeffnoel
1,638
Clovis, CA
Dec 15, 2004
  • Dec 15, 2004
If you get Stumpy's traction bars they are already setup (drilled) for the rear sway bar and replace the rear spring plates.
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
F
Sway Bar Endlinks
  • Fri Guy
  • Jun 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2025
Fri Guy
F
Rear sway bar popped off
  • Creomod
  • Jan 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 16, 2025
limp
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
Views vs attendance - check in and share your experience!
  • LILCBRA
  • Aug 7, 2026
1974 - 1978 Mustang II Talk & Tech Aug 20, 2026
LILCBRA
