Swaybar Endlink help
RBonite
9
Vallejo, CA
After modding my suspension, front swaybar endlink has gone bad due to a loose nut. Nut (attached to the strut) came loose and caused a good amount of tension on the bolt of the endlink which pretty much makes it useless now as the threads are strecthed.
Need to replace, asap. What are my choices in aftermarket endlinks? Will GT500 endlinks work? Or where can I find a stock replacement? I've only come across adjustable endlinks. Any help is appreciated.
FYI, not a racer, just an enthusiastic driver. Definately don't need competition equippment.
Wow. I've had my swaybar nut on the strut come loose and cause clunking sounds, but I was always able to re-tighten it. The hardest part was getting a wrench on the nut in the tight clearance. I worked on it and it has remained tight for quite a while now.
I'd throw up a want to buy thread on the various forums, as there should be people who don't use theirs anymore. I think the GT500 links are the same.
