  • SN95 4.6L Mustang Tech
synchros makin noise
  • Thread starter Thread starter Spro
  • Start date Start date Nov 3, 2007
Spro
73
IL
Nov 3, 2007
  • Nov 3, 2007
With my POS 3650 trans, I noticed my synchros making noise in gears 1-3. I don't get any grinding while shifting. I know there is a TSB on this problem. I still have warrranty on the car. It's an 04 with 25K. I have an MGW shifter on it and the car has other mods as well. My question is, should I put the stock shifter back on before I take it into the dealer or just leave it as is? Also, should I return the stock tune to the car before I take it in? Thanks.
Tim2002GT
635
Tulsa, Oklahoma
Nov 3, 2007
  • Nov 3, 2007
Yes, I would definately put the stock shifter back on. They may try to say the shifter caused the problem with the tranny. I wouldn't worry about the tune tho.
R.J.
813
Warwick, Rhode Island
Nov 4, 2007
  • Nov 4, 2007
Make sure you go to a reputable dealer for this TSB!! My buddy took his Mach1 in for this and the car was worse when he got it back. A tranni fuid swap to Syncromesh, got him better results than the TSB.
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,114
224
Massachusetts
Nov 4, 2007
  • Nov 4, 2007
Fluid level is probably low. It's usually the #1 cause for trans whine and the first thing to check.
I've been lucky i guess with my 3650. 50K miles, no fluid changes, not a peep or grind out of it
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
