The other day I noticed some Mobil 1 5W40 synthetic. I never saw this Mobil1 viscosity, is it new? I might use it, would be great for cold starts and hot days.
External leaking is only the logical problem from using synthetic. The main problem is that it burns clean- if there is a problem INSIDE the engine it won't smoke, so you won't know about it. Dealerships have seen brand new engines trashed internally because something was wrong and the customer ran sythetic, so nobody even knew there was a problem until it was too late- ran like a champ until after the damage was done. It doesn't matter how old the engine is or how many miles are on it, leaking isn't the issue. Older engines are more prone to this kind of problem- that's why it isn't recommended for high mile engines- nothing to do with bad gaskets. Yes, it provides superior protection. What they don't tell you is that you can get the same protection from running one quart of sythetic with four quarts of normal oil as you would with five quarts of strait synthetic. Working in the garage I've seen far more problems caused by synthetic than prevented- read all you want about it. I believe what experience has shown me, not what the propaganda says.sgarlic said:I swapped my wifes Jeep ZJ to Mobil 1 at 166k. It's fine. I swapped my '88 to Mobil 1 at 130k. It's fine.
People who say not to haven't read up. You may develop a leak or two, but if you do, just replace whatever's leaking.
Bottom line: synthetic is so much better for your engine, it's worth replacing a few gaskets.
stangbear427 said:External leaking is only the logical problem from using synthetic. The main problem is that it burns clean- if there is a problem INSIDE the engine it won't smoke, so you won't know about it. Dealerships have seen brand new engines trashed internally because something was wrong and the customer ran sythetic, so nobody even knew there was a problem until it was too late- ran like a champ until after the damage was done. .
No problem, we all have our rants to get out. I'm not supporting dealers- most of the time I recommend private shops. In most regards, I can't stand to talk technology with old time techs anymore. I've been in this business almost two decades, and come from a family of mechanics. The opinion I gave comes from an ASE certified master tech who was not trained by a dealer. I'm not saying synthetic damaged the motor in any way, I'm saying it disguised the problem that was already there. It's rare, but engines do come off the assembly line defective and it's impossible to know until they start to show symptoms. If these symptoms are hidden, things can get way out of hand in a hurry. Almost every engine builder I know recommends using conventional oil until well after the break in period for this very reason amongst others. I know several- and they build race car engines for the speedbowl, not commuter crap or even quarter mile warriors- we're talking 100 lap endurance racing. These guys know their S#!+. I know the owners and techs in almost every shop in this area, and I can say with impunity that there are just as many hacks on both sides of the fence. I don't patronise the dealers regardless... but I don't have to. I hear stories like yours all the time- and I agree. For what they get paid, we expect more from them than blame shifting. I don't want to think about what they would have had to do to blow a stereo fuse on a brake inspection, but it doesn't surprise me. I've gotten taller tales from Mercedes dealers if you can believe it. This all doesn't change the fact of the matter though- be very carefull with synthetic oil. It doesn't matter who's fault it is or who should have caught it before it got out of hand, it's like putting on a blindfold before raiding a terrorist camp because you should be trained enough to smell them. That's all fine and good, but it isn't always that simple. Every engine is a unique case, and you don't always know what's going on inside unless it tells you somehow. No matter how good you are, if it only whispers...vristang said:A brand new engine get trashed internally because somthing was wrong with it. But it is the customers fault, because they ran synthetic oil!!!
With all respect this sounds like something I would hear at a Ford dealership. Ford has a way of saying anything to shift the blame onto the customer, and this is a prime example. If there was a problem with the motor, the mechanic should have caught it, Period. That is what they make their living doing, they should be damn good at it. If not they should at least be better than my hack-@$$.
The last time I took my car to a dealership was for a brake inspection. Not repair, just inspect. Before handing over the keys I turned the sound system off. When I picked the car up the sound system was dead. When I brought the car back to have the dealership fix it, they looked at it for an hour, then told me that the car stereo shop had messed up on the install and that they didn't do anything that would have caused the problem anyway. I have had that system in place since 97 and have never had any such problem. How do you blow a fuse to a stereo that is turned off, while doing a brake inspection? HACK is how.
Sorry for the rant, but I can't stand to hear anyone talk up dealership mechanics anymore.
Synthetic oil was not the cause of any of the failures you described. Don't jump on the Dealership Tech bandwagon and only believe what the old time techs tell you is the truth.
