Synthetic gear lube
shane93nc
208
charlotte,nc
Is synthetic gear lube really needed or would regular gear lube be good enough for an 02 gt with less then 15,000 miles.I am having the 4:10's put in next week and the installer told me to get either one i wanted.Thanks Shane
I personally would recommend synthetic as thats what your car comes with stock in the rear differential. If you wish to go with regular, I guess thats fine too. Just dont forget the friction modifier.
Thanks.....i didn't know that it came from the factory with the synthetic lube.....i will make sure that i replace it with it then.
I would probably get some cheaper dino lube for the initial fill, run it for 500-1000 mi, then replace it w/ your good stuff.
while were on this topic... is Red RTV OK to use for gasket material on the 8.8?
