Systemax II heads
  • Thread starter Thread starter 86bluecobra
  • Start date Start date Jan 4, 2006
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 4, 2006
  • Jan 4, 2006
Anyone running these heads?
Do you know if the respond well to porting?
Do they have issues with stock flow numbers?
I'm considering a port job curious if anyone has already done it to these.
Rick 91GT
Mustang Master
95
99
PA
Jan 4, 2006
  • Jan 4, 2006
What PT# heads are they?
They respond well to some short turn work and some bowl work, and a few other changes..
I have the stock flow numbers at the shop, the only thing I do not like is they have a 1.78" installed height, I'd prefer a little more on some of the more aggressive cams. A switch in the retainers and or locks can get you more height.
I've worked on a few sets, and I am just finishing up a older set (ped mount, 1.94" int x 1.60" exh)
304billet
315
  • Jan 4, 2006
I would not waste the time or money. Their r way better heads out there for a 351 - AFR 205's TFS R, ported Victor Jr's.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 4, 2006
  • Jan 4, 2006
i realize there are better heads out there but 500 bucks as apossed to 1700 bucks is my issue. have a 2 year old and a 3 month old. my heads are the 1.94 intake 1.6 exhaust. bought them maybe 5 years ago. i think the part number was something like 300-551 maybe.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Jan 4, 2006
  • Jan 4, 2006
There actualy not bad looking heads,from what I see on Holley.I think a little porting and they would probable beat average TFS Track Heat flow numbers,even with the smaller 1.90" valves.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 5, 2006
  • Jan 5, 2006
i got roped into buying these heads and i don't really have the cash to buy other heads that would flow better. afr 205 are on my wish list but that maybe a while till i get them. right now i want to continue to stay ahead of my brother in laws 68 dart running a 440 4spd. he ran a 12.95 1/4 mile time at the track i ran a 13.05 N/A. so really he is a little ahead of me but with nos i had him. my car was bogging bad when i wasn't running the nos.
Rick 91GT
Mustang Master
95
99
PA
Jan 5, 2006
  • Jan 5, 2006
They are small for a 351W, they respond well to a 2.02" intake valve upgrade, you have the first gen heads
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 5, 2006
  • Jan 5, 2006
no problems with shrouding for a 2.02 upgrade?
Rick 91GT
Mustang Master
95
99
PA
Jan 5, 2006
  • Jan 5, 2006
I assume you mean on a 4.03" bore? They larger valve really helps on those heads, the new version they went to already had it done.
To make them good for youe combo it would cost over $500, for a few hundred more you could go with a Vic Jr that would yeild better results, but the AFR would yeild the best results and is really what I woudl recommend on your combo.
Why not sell the Holleys and upgrade when you can?
I went 11.8 @ 116mph 340RWHP on a NA 302 8.8:1 comp with the Holley heads and Intake, AFM cam etc, on a 175 shot I went 11.0 @ 131 and the car made 540RWHP/742RWTQ No traction
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 5, 2006
#10
  • Jan 5, 2006
  • #10
nice times i am assuming you have suspension mods to help pull off those times. grrr maybe i will hold off on putting cash into the heads and just have the car tunned on the dyno instead. that way i can put those holley heads on my pickup when i get some afr heads for my car. according to my mph when im on juice the calculators say i am making 428 rwhp with a 410 rwhp average.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 5, 2006
#11
  • Jan 5, 2006
  • #11
i wish i could just port them myself and it wouldn't really cost me anything. btw the exhaust valves were upgraded to some nitrous valve. the shop that did it also cut down the valve stem . you can see how they tappered the valve stem through the exhaust port. they claim 5 cfm more flow on the exhaust that way.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
