T-3650 Swap In A 2000 Gt
jhop308
T 3650 swap in 2000 gt. Bought a t3650 transmission had t45 that 3rd in 4th are gone. I wanted to buy a new clutch an I already resurfaced the flywheel. I went to put my new clutch stage 2 on and the clutch won't go on flywheel because it's to small 8 bolt flywheel. Can I order a clutch for a t45? I know input shafts are the same I'm assuming looks the same 10 spline. What do I need to do to complete the swap advice would be appreciated
Having trouble understanding the post. But in general the two transmissions interchange as long as the OSS speed sensor has the same number of teeth.
If the number of OSS teeth are different the speedometer will be wrong. However this can be corrected with a modified tune.
But it seems to me that there's something else going on here. The clutch need to match the flywheel. 10.5" verses 11". The only consideration that needs to be made for which transmission is being used is the number of splines on the input shafts. Match that and it should work together.
