  • SN95 4.6L Mustang Tech
T-45 issues
  • Thread starter Thread starter crzyhrse99
  • Start date Start date Oct 15, 2007
crzyhrse99
259
Kansas
Oct 15, 2007
  • Oct 15, 2007
I know its allmost impossible to diagnose a sound on here but its worth a try, maybe some of you have had this experience b4. I'm hearing a faint metallic sound like metal on metal when shifting the car into first when coming to a stop. Also am hearing the same sound when pulling out from first.
The sound is coming from the tranny area, Im pretty sure its not the clutch as I have heard it with the clutch engaged/disengaged. Shifter/shifting feels like it always has, no grinding, no extra nothchiness. I'm just worried my tranny is gonna go, my beater car lost its tranny last week so the stang cant go down .
99GT 115k
T
Two Wheel Peel
94
PA
Oct 15, 2007
  • Oct 15, 2007
I would try jacking up the car and takeing a look underneath. That metal on metal sound could be comming from the h-pipe rubbing against something.
Also, check the metal bracket that holds up the transmission. My car was making some odd sounds and I found out that I was missing one of the two bolts on that metal bracket. My tranny was rocking left and right making noise because that bolt fell out.
bill302
2,131
alabama,gadsden
Oct 15, 2007
  • Oct 15, 2007
check the u-joints...
crzyhrse99
259
Kansas
Oct 15, 2007
  • Oct 15, 2007
I took a visual underneath when I got home, i'll pull it up on the ramps tomorrow to check for any missing bolts......I did just install a upr x 2 wknds ago so that could be a good possibility and I hope thats it.
bill302, I had to replace a u-joint on a f150 I had a couple years ago.....those made a horrible sound and loud, this is more like a "creaking" metallic faint sound.
the98stang
2,408
Clovis, CA
Oct 16, 2007
  • Oct 16, 2007
how does the tranny oil look?
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Oct 16, 2007
  • Oct 16, 2007
check for the trans mount too. I've seen one ripped making noise before
C
cooter_11
138
GA
Oct 16, 2007
  • Oct 16, 2007
I'd say check the trans mount
9
96SLPGT
Pennsylvania
Oct 16, 2007
  • Oct 16, 2007
i broke the guide shaft for the throw out bearing on mine it sounded like a piece of metal flyin around in the bell housing..because it was lol. the sound would happen randomly too. sounds like that might be ur problem. i hope not for ur sake though.
crzyhrse99
259
Kansas
Oct 16, 2007
  • Oct 16, 2007
Thanks for all the suggestions on what to check for, didnt get home early enough to get it on the ramps to take a look around. Im gonna try to drive the wifes car for the rest of the week and ill look it over this wknd and put in some fresh mercon3.
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech 22 minutes ago
Mindseye007
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
