will the 3650 5spd work in my 97gt with no probs, direct bolt, so on so forth?, if so whats the easiest way to tell the 3650 vs. the t45
In order to use the 3650 in a 97 you need a 3650 clutch and flywheel. Easiest way to tell is either get under there and look. 3650 will be beefier and typically be tagged tremec. Also look at the door code.
it was a 'direct bolt in'?
get an extended range speed-cal. New driveshaft as well. Everything else should be fine.
Why would he need a new driveshaft?
I was just guessing they were different in length. I have not done a t-45 to 3650 swap. Just my aode to 3650 which called for a new one.
Just put a t3650 and an 03 mach 1 engine into my 98gt, the cross memeber needs to be notched out to fit the t3650 however, some people say they have had vibration problems due to not notching the proper angle. I am going to try the crossmember for a t3650 and see if it mounts to the 98
