T-5 Compatibility/Crazy Allignment
  • Thread starter Thread starter fastfutura
  • Start date Start date Jun 23, 2005
F
fastfutura
29
Flagstaff, AZ
Jun 23, 2005
  • Jun 23, 2005
I am interested in purchasing a 94 cobra t-5 to install in my 1989 LX 5.0. Is it possible to do this? I know the input shaft and retainer is longer but can they simply be replaced with the shorter length components? My stock tranny grinds pretty bad in second and if I can get a better tranny to rebuild I will. I just don't want to get stuck with a tranny I can't use.
Also, my Mustang pulls hard to the left, even after numerous allignments. It is a bone stock Mustang with Goodyear GT II tires. The tires are not wearing unusually. The faster I go the harder it pulls. Would I be able to correct this with camber plates or does anyone know what could be wrong. I don't think the brakes are dragging and the suspension is in good shape.
This is my first post here. I have had my car almost a year and I am hesitant to put any cash towards modifying it if it keeps pulling hard to the left. It is very annoying and unsafe. I also need to change my heater core out. I can't justify keeping my car let alone spending money modifying it if I can't get it to go straight down the road. I would appreciate any suggestions.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 23, 2005
  • Jun 23, 2005
instead of swaping the imput shaft you can just run the 94/95 5.0 bellhousing. also you might need a different D/S if you do that though.
might sound dumb but have you checked tire pressure? mine pulled to the right, i checked pressure and evend em both out and its been fine since
F
fastfutura
29
Flagstaff, AZ
Jun 23, 2005
  • Jun 23, 2005
What is a D/S?
If I used the 94-95 bell housing, would that move the shifter back a little? Would that be a problem? What is a D/S?
I have checked my tire pressure a whole bunch of times. One guy who looked at it said it looked like the rear tires were off a little. He drove it and said it felt like the rear was pushing right making it drift left. I am going to get that checked out. One guy suggested camber plates in order to be able to get the alignment to compensate for the pull but I was wary of having my allignment out of factory specs.
I_AM_CANADIAN
189
B.C.
Jun 23, 2005
  • Jun 23, 2005
d/s=driveshaft. If your car is lowered, it is better to have c/c (caster/camber) plates, this should cure your alignment problem.
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
Fox Ideas for Theft Deterrence in Storage
  • Clutchfork
  • Nov 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2025
91AOD5.0LX
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
