T-5 conversion driveshaft yokes...
  • Thread starter Thread starter SadbutTrue
  • Start date Start date Jul 18, 2007
SadbutTrue
2,390
Thousand Oaks, California
Jul 18, 2007
  • Jul 18, 2007
I've been told if I use the right output yoke I might not have to have my driveshaft shortened (certainly desirable). Does anyone know if an NPD swap output yoke for a 66, when used with a late bell and input shaft, will accomplish that? If not, can I get one that does (and from whom)? Thanks!
edited... probably m akes more sense now.
G
Gud T.B. Blown
583
Jul 18, 2007
  • Jul 18, 2007
SadbutTrue said:
I've been told if I use the right output yoke I might not have to have my driveshaft shortened (certainly desirable). Does anyone know if an NPD swap driveshaft for a 66, when used with a late bell and input shaft, will accomplish that? If not, can I get one that does (and from whom)? Thanks!
How does the conversion yoke work? You don't want the yoke to stick out much more than 1" from the trans.
jcode68
892
Massachussetts
Jul 18, 2007
  • Jul 18, 2007
I got lucky with my swap in my 68 and didn't need to shorten my driveshaft. Based on what I have read, this is total luck of the draw as some do and some don't. My guess is the variance in tolerances for things like engine mounts etc can swing to a high enough degree to make it possible or not. I don't think it's a matter of which yoke you get since they all must be the corect spec. I'm sure you will get a lot of responses on this thread since this is a popular swap.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Jul 18, 2007
  • Jul 18, 2007
As far as I know, the conversion yoke only allows you to run a regular u-joint instead of a conversion u-joint.
SadbutTrue
2,390
Jul 18, 2007
  • Jul 18, 2007
whoops posted on wrong forum...
by any chance does a c4 yoke fit into a t5 (might as well make sure it doesn't before i go to npd)...
BornInAFord
199
Bend, OR 97701
Jul 19, 2007
  • Jul 19, 2007
I used a conversion yoke from Darkhorseracing.com fpr my 66 T5 conversion with a stock 4 speed V8 driveshaft. It was $70, IIRC, and is about 3/4" shorter than the stock T10 yoke I had. Using it, I did NOT have to shorten my driveshaft as the shorter yoke allowed me enough room. I still have the inch play required and don't bottom out inside the transmission like the longer yoke would have done. I don't know if the C4 driveshaft is the same length, however. I think yours may be shorter, even. 50" vs 51"???
Daniel
SadbutTrue
2,390
Jul 19, 2007
  • Jul 19, 2007
Daniel
Can anyone comment to that?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 19, 2007
  • Jul 19, 2007
When I switched from a C4 to a T5 in my 67 I had a new drive shaft made because my driveshaft was a 2 piece. You don't want a 2 piece drive shaft. Check to find out if your is a 1 or 2 piece before you worry if you can buy a new yolk for it or not.
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Yesterday at 4:24 PM
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
A
T5 conversion questions
  • Animal Lawyer
  • Jul 9, 2021
5K
Classic Mustang Specific Tech Aug 6, 2021
manicmechanic007
T-5 input shaft for a Mustang 2 Bell housing
  • Steve FLeming
  • Feb 5, 2020
5K
1974 - 1978 Mustang II Talk & Tech Aug 25, 2022
IICrew
I
