T-5 QUESTION
  • Thread starter Thread starter gtcobra302
  • Start date Start date Jan 26, 2006
gtcobra302
118
Centra Florida
Jan 26, 2006
  • Jan 26, 2006
I have a question about a World class T-5 that noone seems to be able to answer. On the cover of the case that holds the shift rod and forks what is the sensor that screws into the cover? Its not the reverse switch and I'm pretty sure its not the neutral safety switch. I have an 89 gt and it broke when I rebuilt the transmission and it didn't seem to make a difference. The 93 I just got has the same sensor and it is also broken. Does any one know? Does it matter?
Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 26, 2006
  • Jan 26, 2006
If you are talking about item #6 in the attched drawing, it is the neutral sense switch. It is used to tell the computer the trans is in neutral so that the KOEO codes can be dumped.
FordMuscle
Banned
Dec 19, 2002
69
California
Jan 26, 2006
  • Jan 26, 2006
ding ding ding ,we gotta winna folks!
yes it is the NSS.
if you need, here is an online T5 rebuild article:
http://www.fordmuscle.com/archives/2005/12/T5Rebuild/index.php
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 26, 2006
  • Jan 26, 2006
It is an NSS.
Car will run without it, but you won't be able to dump codes because the EEC can't see if the car is in nuetral. Not all t-5's have them
LilRedPony
31
Arizona
Jan 26, 2006
  • Jan 26, 2006
You could probably wire it closed so the computer still thinks the car is in neutral, that way you can still dump codes.
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
