T-5 question
  • Thread starter Thread starter fastfutura
  • Start date Start date Jan 29, 2006
F
fastfutura
29
Flagstaff, AZ
Jan 29, 2006
  • Jan 29, 2006
My local pick and pull is having a half off sale Saturday. I plan on getting a 4 cylinder T5. I want to put it into my 5.0 so I can drive it while I rebuild my V8 T5. I figure that I can then sell the other T5 when I swap the original one back in.
I know I would need the special pilot bearing to do this. Can I use the bell housing from the 4 cylander T5? Is their anything else that needs to be done to do this?
Also, if anyone needs the parts (clutch pedal, linkages, etc.) to convert their auto to t-5 I can pull these parts when I get my tranny and send them to you if you want.
ryanp
30
  • Jan 29, 2006
no you can't use the bellhousing from the 2.3....just unbolt the bell from the 2.3 T5 and bolt on your 5.0 bell. everything else is the same except for the input shaft but you already know that. hope that helps
HISSIN50
34
129
Jan 30, 2006
  • Jan 30, 2006
There have been two good threads today about this. Take a look for them perhaps. TheBozSez has found some info about his, for instance.
Good luck.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
