T-5 swap headache
  • Thread starter Thread starter given2fly71
  • Start date Start date Sep 2, 2006
given2fly71
  • Sep 2, 2006
I thought I did all my homework before I started, but I guess I was wrong. I've read through many posts but cant seem to find the same problem to answer my question. Here is the deal: I have a 67' with a 351w with a c-4. I gathered up all the parts for the t-5 swap, and now that I have the trans in I can see that the cable setup is going to be a nightmare with my long tube headers. I have about an inch of clearance from where the cable comes out of the bell housing, is that too close? Should I look into a new set of headers? Or should I just stop with the cable setup and think about going with the hydraulic setup?
rbohm
6,698
550
204
tucson,az
Sep 3, 2006
  • Sep 3, 2006
if you have a T5 bellhousing, go hydraulic.
jcode68
892
Massachussetts
Sep 3, 2006
  • Sep 3, 2006
+1 for the hydraulic. Lots of guys reporting problems with the cables sticking due to the heat from headers. Hydraulic allows you to plumb the line anywahere you want/need to. Are you running or plan to run power brakes? If so, that will present another challenge.
LMan
1,246
Mom's basement
Sep 4, 2006
  • Sep 4, 2006
I don't know how you 'did your homework,' yet failed to see that cables + LT headers = trouble. That's probably the one thing every T5 swap thread/article/etc belabors over and over.
I have a cable on mine, but I moved a primary tube over. Took an hour or so, but saving $400 was well worth the time invested.
YMMV.
given2fly71
  • Sep 4, 2006
Thanks for the advice guys. Hey LMan, as my post says "I thought", I did my homework, and yes I did see posts talking about header trouble, but you never really know what problems you will have untill you get into it. My first thought was to re-locate the tube that is causing me problems. I think I may go that route. How close is too close when it comes to the cable in relation to the header tube? I have a little over an inch, so I was thinking of wrapping the header at the "trouble spot", and fabricating a protective sleave for the cable.
M
mikemustang289
224
mesa, az
Sep 4, 2006
  • Sep 4, 2006
An inch is fine. Mine runs pretty close and I fabricated a bracket to hold it from touching the header. As long as it doesn't touch you'll be fine.
given2fly71
  • Sep 4, 2006
Thanks mikemustang289, thats the answer I was hoping for. Now that I have The bell all tightened up, its a little more than an inch. Thanks again for all the advice guys..
M
MitchGT
204
Sep 4, 2006
  • Sep 4, 2006
you can also put on a little heat resistant covering over the cable. I put some on my starter and it made a world of difference.
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
