- Nov 16, 2003
- 37
- 0
- 6
I'm almost finished with my T-5 swap and until now it went along fairly smooth. Currently the everything is installed except the starter because for some reason it will not fit into the bellhousing. I bought the bell-housing from a junkyard and it had 86 written on it in paint pen so i assumed it was out of an 86 mustang. Everything bolted up fine to the bell-housing except the starter. When trying to put the starter on i first thought that the hole in the index plate might be too small, but it is the same size as the hole on the aod plate. My next assumption is that the snout on the starter might be too long but then when i go up to the parts store and have them search for different starter's in 86 5.0's... they are all the same. What is going on here?? Is it possible that this bellhousing is off a different vehicle that requires a different starter?? help please.
