t 5
  • Thread starter Thread starter check
  • Start date Start date Apr 28, 2007
C
check
  • Apr 28, 2007
my t5 transmission grinds when you change gear first thru five
HISSIN50
34
129
Apr 28, 2007
  • Apr 28, 2007
Check clutch adjustment. If it's ok (read zero lash or even preloaded for diagnostics), consider clutch failure.
Good luck.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 28, 2007
  • Apr 28, 2007
How old is the t-5? I doubt it is syncro's if every gear is doing it. Hisson is correct with his clutch adjustment comment. Thats where I would start looking first.
C
check
  • Apr 28, 2007
its an 89 coupe origanal trans i will adjust clutch maybe it will work
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 28, 2007
  • Apr 28, 2007
See the "Useful Technical Thread Index" sticky at the top of the forum. In it you will find Clutch Cable/firewall adjuster/quadrant installation and adjustment - by V8only. Everything you need to know is in there.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Apr 28, 2007
  • Apr 28, 2007
if its the stock quadrant a cable setup, just pull up on the clutch pedal it should pop up some and then press it down again and viola its adjusted. if you have aftermarket cables and quadrants it more complicated. thats why you go to the links jrichker provided above
4G-KDMP
935
CA
Apr 28, 2007
  • Apr 28, 2007
clutch or syncro's!
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
