T-56 upgrade?
The T45 in my '96 Mystic Cobra needs a second gear synchronizer and 1-2 shifting fork. Still driveable but only allows slow deliberate shifts to second. My question: Is there a way to swap to a T-56 or TKO and still have a working speedometer? Are there any manual speedo adapters available? If I have to pull the tranny and repair/replace it I feel like it would only make sense to replace it with a better unit but I want everything to work.
you can swap in either and the speedo will still work. just amke sure to tell whoever you order it from that you have a mechanical speedo. i would highly recomend the T56. i installed mine about 3 weeks ago and i love it!!!
Saleen, how much did the tranny upgrade cost altogether?
no tire spin with a blower and street tires! that sounds like a dog down low.:shrug: it might actually be good for times though because you have the traction the whole time. it just sound like its lagging if it cant break the tires loose.
ADRENLN said:
i thought the t-56 made our cars real sluggish down low in the rpm.:shrug:
1st gear is longer so you get less wheel spin and can push it to 45mph or so :nice:
Following ratios are closer, 4th is 1:1 identical.
Then you get 5th OD and 6th at 0.62 OD for the freeway cruising. Lovely!
Maybe you think it's sluggish down low cauz you don't make power there... I never had this feeling, I just went 315 in the rear to avoid wheel spin on 3rd gear at 50mph :D
i dont have the tranny, i just read that people need the 410 gear or higher to make the t-56 feel good. i really wouldnt want to go over 3.73 in the rear which is what i have now. any higher and rpm would be too high while driving.
although going to 45mph in first sounds awsome.
I also think 3.73-3.90 would be perfect, any lower and you have a 5 speed again. LOL
You lose HP with this mod I hear thru drivetrain loss.
I was gonna buy from DD cause they have a kit with driveshaft.
Kit consists of a rebuilt 03-04 Cobra T56 transmission, cross member mount and aluminum driveshaft with the correct slip yoke. All the parts you need for the conversion. These transmissions are rebuilt by the technicians at D&D Performance, a Tremec elite Distributor and Factory Authorized repair center
K3 BA3(Ford 4.6 Mech.Speedo) Standard version into 96-98 Cobra $2799
