t-bird to fox disc brake questions
Raginstang
166
SANTA CRUZ CA
I just bought a rear axle from an 88 thunderchicken and want to drop it in my 89 stang for the rear disc brakes. I was just wondering what all I would need to make the rear disc brakes adapt? meaning the lines etc. do I need a different master cylinder? and proportoining valve.? just let me know. thanks.
Been there and done that! With success! :nice:
It takes 2 guys the first day to get the old rear end out and the new one bolted in place. It takes 1 guy another whole day to do the brakes.
Auto trans Turbo Coupes come with 3.73 gears and manual Turbo Coupes come with 3.55 gears. I choose 3.55 since I do more highway driving.
You will need a several sets of fittings, I recommend that you get them from Matt90GT's website, http://www.svo73mm.cjb.net/. Read Matt's instructions thoroughly, everything you need to know about the brakes is all there. You need to be patient and follow all the internal links, and there are many of them. You will need 2 fittings in the rear to adapt your old brake tubing to the TC disk brakes. The fittings go between the steel tube and the caliper brake hose. You will need another set of fittings to make a 2 port to 3 port adapter. To make life simpler, just buy the kits from Matt. You could piece them together, but it's not worth the time unless you work at an auto parts store with all the fittings ever made. You will need to drill the quad shock mounting holes 2” below the holes drilled for the Turbo Coupe mounting points. The bolts are metric, so don’t loose them or the nuts. A 15/32” drill should be about the right size unless you have access to metric sized drill bits. Going without quad shocks is not an option unless you have aftermarket parts to soak up the wheel hop.
You will need a proportioning valve, Summit has one for $40 + shipping.
You will need a kit (FMS makes the part) to gut the stock proportioning valve, Summit also has that, about $10.
You will need a new master cylinder, see Matt's site and make you choice. I used a 94-95 Mustang master cylinder. Note that rebuilt 94-95 Mustang master cylinders do not come with a reservoir. That means a trip to the junkyard and some more money spent.
Your brake pedal may be very hard and almost impossible to lock up the brakes. I had to replace the front calipers with 73 mm calipers from a 91 Lincoln Mark 8 to get the braking performance up to par.
See http://www.mustangcentral.net/tech/brake.html for help with the emergency brake. The ebrake handle on 87 and later models must be modified by removing the spring, and tack welding the pawl and ratchet assembly.
Bleeding the brakes will require 2 people and some coordinated effort. I don’t recommend using you wife or girlfriend to pump the pedal – they get offended when you yell at them. I used a homemade power brake bleeder constructed from a garden sprayer and some fittings from Home Depot. It cost about $25 and was worth every penny.
All in all I have been very pleased with the results.
hey, thanks soooo much for all the help. I have just one question though. you said its impossible to lock up the brakes. until you slapped on the 73mm units.. does that mean the rear upgrade didn't help any? i thought going to the rear disc would help performance
thanks. Mike
