T5 5th & speedometer question
795.0pacecar said:
Sounds like maybe the C clip that holds 5 gear in poped off causing the gear to slide down the shaft and knock out the speedo gear.
Bingo
I think Foxfan88 has this problem last month. If you search his name you might be able to find the thread. I posted pics and everything.
What happens is the c-clip slips off due to the clip bending when reinstalled after a rebuild. WHen it comes off it slides forward with some force and can knock the speedo gear off.
These parts are in the tailhousing, so they are separate from the main gears. You don't even need to open the main case up, just need to pull the tailhousing off. WIll cost you a the price of a c-clip and the speedo clip to fix.
